Architect or LandmarkInserting stake objects
Tool
Tool set
Stake
Design Suite, Architect, Landmark: Site Planning
Stake objects represent a 3D point in space, with text to display the elevation, coordinate points, or other information. Using a stake object, the elevation information for a point on the site model can be determined and labeled. A stake object can be used as a site modifier. If the file and design layer are georeferenced, a stake object can be used as a geographic marker.
Advanced users with georeferenced files who have selected Latitude/Longitude (WGS84) or Longitude/Latitude (WGS84) as the Label Reference for the stake can place additional datum grid files in the Plug-ins/Common/Data folder within the User folder. The added grid files provide increased precision when converting to WGS84. Datum grid files can be obtained from PROJ.
Mode
Description
Standard Insertion
Inserts a single stake object
Vertex
Inserts a stake at each vertex of the drawn polygon shape
Preferences
Sets the default preferences for the stake object
Elevation
Sets the default elevation value for stake objects
To insert a stake object:
Click the tool and mode.
In addition to using the Stake tool, multiple stakes can also be inserted in a grid pattern by Adding source data by grid method entry.
Click on the site model to place the stake object, or draw a temporary polygon to place a series of stake objects at each click point and double-click to end the series.
The first time you use the tool in a file, a properties dialog box opens. Set the default parameters. The parameters can be edited later from the Object Info palette.
To automatically increment the ID parameter when placing new stake objects, select Auto ID Numbering and specify an Initial ID Number. Otherwise, leave Auto ID Numbering unselected and specify the default ID Number for stake objects.
The stake objects are added to the drawing at the elevation specified in the Tool bar.
Select the Send to Surface command to set the stake elevation to that of the site model surface (see Sending objects to the surface).
If the stake objects are site modifiers, update the site model to apply the changes (select the site model and click Update from the Object Info palette.).
Move the control point to adjust the label and leader line position. If there are several stake objects, use the Align/Distribute Leader Lines command to improve readability (see Aligning and distributing leader lines).
Parameter
Description
Z-value
Specifies the stake elevation.
To create road stakes with the Vectorworks Landmark product, set the elevation of the first stake along the polyline; the elevation of the remaining stakes is automatically calculated (as described in Setting stake elevations).
Rotation
Rotates the stake object indicator and the label (if applicable) around the stake object indicator’s center
Mode
Include as site model data
Uses the stake as site model data if it is located in the source data layer (select when using stakes to create a site model)
Set elev to site model
Sets the stake elevation to the existing site model elevation
Use as 2D/3D graphic only
Uses the stake as a drawing element that does not interact with the site model
Site modifier object
Treats the stake object as a site modifier, which has an effect on the site model
Site Model
When the stake object is used as a site modifier, specifies whether it affects the existing or proposed site model
Style
Selects the graphic style of the stake object indicator
Bubble Style
Selects the graphic style of the bubble drawn around the stake’s value
RR Corner Radius
For Round Rect bubble styles, sets the corner radius
Text Margin
Sets the distance between the bubble and the text
3D Display
Sets the appearance of the stake object in 3D views.
None: no 3D display is created; the stake object displays like a 2D planar object.
Locus: a 3D locus is displayed.
Extrude: a rectangular extrude extends upward from the stake elevation; specify the width and height of the extrude.
Mark Offset X
Offsets the stake object indicator from the insertion point along the X axis
Mark Offset Y
Offsets the stake object indicator from the insertion point along the Y axis
Mark Rotation
Rotates the stake object indicator around its center
Label Reference
Selects the type of information to display in the label; select No Label to display no text. The available label fields depend on the label reference selected.
The Coordinate Point (YX) label shows the distance along the Y axis for the X value, and the distance along the X axis for the Y value, to be compatible with other software programs.
Label Position
Specifies the alignment of the label, and which side to place the leader line (when displayed):
Auto: Automatically determines whether to place the text on the left or right, depending on the position of the label related to the stake's location
Right: Places the text to the right of the label control point and left-justifies the text
Left: Places the text to the left of the label control point and right-justifies the text
Center: Centers the text on the label control point
Description
For description type labels, enter description text
ID Prefix
For ID type labels, enter a prefix to display before the ID number
ID Suffix
For ID type labels, enter a suffix to display after the ID number
Auto ID Numbering
Automatically increments the ID number parameter when inserting new stake objects
(Initial) ID Number
For ID type labels, specify the ID number. When Auto ID Numbering is selected, the ID Number field changes to Initial ID Number, and ID numbers will be automatically incremented beginning with the initial number specified. When Auto ID Numbering is not selected, specify the default ID Number for stake objects.
Station Point Data
For Stationing Data labels, indicates the station point data for the selected stake object
Coordinate Point
Coordinate point type labels can show the stake's distance from a point of origin (user origin), or they can show the stake's geographic position (latitude and longitude) if the design layer is georeferenced (see GIS and georeferencing).
To display distance, specify Document Units, Feet, or Meters as the Coordinate Units. The Coordinate Point (NE - Northing-Easting) and Coordinate Point (EN - Easting-Northing) options display the distance prefixed with the direction (N, W, S, E). The Coordinate Point (XY) option displays the distance prefixed with the file coordinates (X, Y).
To display longitude and latitude, specify Decimal Degrees or Degrees/Minutes/Seconds as the Coordinate Units (or simply select the one of the longitude and latitude labels).
If the stake object or user origin moves, the coordinates automatically update to reflect the change.
Coordinate Units
For coordinate point type labels, specifies the units to use for the coordinates.
Select Document Units, Feet, or Meters to show the stake's position relative to the user origin of this drawing.
If the design layer is georeferenced, select Decimal Degrees or Degrees/Minutes/Seconds to show the stake’s geographic position.
Coordinate Prec
When coordinate point type labels are set for units of Feet, Meters, Decimal Degrees or Degrees/Minutes/Seconds, specifies the precision with which the measurements will be labeled
Show Elevation
For coordinate point type labels, displays the elevation below the other coordinates
Elevation Units
For elevation type labels, and for coordinate point type labels when Show Elevation is selected, specifies the units to use for the elevation.
Select Document Units to use the same units as the document.
Select an imperial or metric unit to show the stake's position relative to the user origin of this drawing.
Elevation Prec
For elevation and coordinate point type labels where the specified elevation units are not set to Document Units, specifies the precision with which the measurements are labeled
Show Unit Mark
For elevation and coordinate point type labels, displays the unit mark along with the unit value
For coordinate point type labels, if Document Units are set for Coordinate Units, the unit mark visibility is determined by the document setting.
Display Leader Line
Adds a leader line from the label to the stake object (adjust the leader line position by moving the leader line control point)
Scale Factor
Determines the size of the stake object indicator
Set Geolocation
Opens the Set Geographical Location dialog box to enter the desired coordinates; see Adding a GIS Stake
Converting 3D loci to stake objects
Creating a site model section
Calculating and displaying grade and elevation
Creating the site model
Updating a site model
Adding a GIS Stake
